dayoagogo
jammy i have been in touch with a guy that is willing to change and code the canbus and it doesn't seem a bad price i have sent you a message about this>
Yep I'm afraid to say that I did disconnect the battery (had it disconnected throughout the entire process)
Any more info inc pictures in accessing the Can Gateway guys?
I'm wanting to plug a Polar Fis+ into mine.
Any help would be very much appreciated.
Just unplug the red plug, plug that into Polar and the lead into gateway
B0llocks!! This is the only thing it can be - as I doubt Seat needed to designed a new MFD when everything else works on it!
It's got to be a coding/communication issue from the rns 510 to the MFD.... just to reduce the space between the arrow & clock!?
I would ask someone that has the rns 510 (without the clockshift issue) for all there settings / coding in the can bus gateway & navigation.......... as I reckon this is the key!!!
what is a Polar Fis+?
i thought the clock shift issue was because of the fact that the 56 plate screen uses a larger font to display the compass and clock. I guess that it has a lower resolution than the 58 plates lcd and that changing the lcd next to the fuel/temp would cure it, not changing the canbus.
