Does anyone know where the can bus gateway is located in the leon?
FOUND! SEE BELOW
FOUND! SEE BELOW
Nope, have looked for it but never found it. Have a feeling that its behind the instrument cluster/under the steering wheel.
Depends what you are reading off the Can, but there is a twisted pair on the quadlock connector on the rear of the radio. They are labelled up as 'Can H' and 'Can L'.
jammy did you get to the canbus gateway is it a difficult job to get too? is it located in passenger footwell as i don't know where the point your talking about is
Jammy when you do find a way can you let me know and i'll see if i can change mine to sort my clock out. Have you bought the canbus yet? Do you need to get it coded when fitted
