cheers
I think you will find that the only way you can adjust the camber like that is if you have coilovers fitted... You might be able to get a lil bit of adjustment out of the bottom ball joint!![]()
no, its on all models, ive got a 96 pre facelift 1.9d base spec and the camber is fully adjustable, large amounts too, as i had to do it after fitting alloys
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
