cam options
myseatcupra
ibiza fr tdi
May 14, 2007
791
cardiff/penarth
i've been looking in to what cams to get and im a bit lost.
im after something that will give me good power but with out moving it up the rev range to much( if that even posible) with a good idle.
i was looking at newman cams (as they seem a good price)and there road cam is 264/264 i always had the idea that both cams were different should this be the case?? Is a blank cam newly machined i,e not remanufactured. i see stu has got 275 cams in his motor is that big power high rev's?
if i went for the 264 cams with other work is it posible to get some where near 170/180hp or shold i look for something a bit lumpyer.
1 last thing i read on here may of been robT said its best to leave the exhaust cam as it is. any reason do you know
thanks peeps:)
http://www.newman-cams.com/pdf/volkswagen
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
std ecu? ABF?
partnr.
duration
duration
maximum lift
lift at TDC
parts
application
[data link]
[0.1mm+cl]
[1.0mm+cl]
[cl=0]
[cl=0]
(TURBO)
7661207
261 / 261°
221 / 221°
11.20 / 11.20mm
1.05 / 1.05mm
O.E.M.
HYDR: sport
7661206
262 / 261°
226 / 221°
11.60 / 11.20mm
1.35 / 1.05mm
O.E.M.
HYDR: sport
7661210
266 / 262°
228 / 229°
10.90 / 10.90mm
1.45 / 1.40mm
O.E.M.
HYDR: sport
CatCams... but ABF ecu will struggle to hold emissions on much frutier than these.
myseatcupra
ibiza fr tdi
May 14, 2007
791
cardiff/penarth
sorry left the inportant info out. abf running standard management. but thinking of changing ecu for something lke megasquirt.
im guessing catcams are what you selling? you got any prices for them.
myseatcupra
ibiza fr tdi
May 14, 2007
791
cardiff/penarth
as ive no idea what all the numbers mean
261 / 261° 7661207
221 / 221°
would i be right that its the degrees of the 2 exhaust valve and the 2 inlet valve. or am i wrong on this one
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
I sell Schrick and CatCams, but CatCams have a wider range of profiles.
£399+vat for catcams
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
the numbers are duration for inlet & exhaust cams, lift, lift @ tdc etc
you will have more options on megasquirt in respect to idle control and lambda regulation (or none at all)
