Calipers
Kirman93
31
Just wondering if anyone has had their calipers sprayed and what colour? Any photos?
Rob McCool
71
13
Birkenhead
When the calipers started to look a bit tired on the fr170 I used to own I hand painted the calipers and disc edges with smooth silver hammerite-it looked good and was very hard wearing.
Sent from my GT-I9195 using Tapatalk
concerned cat
497
Huddersfield UK
Smooth Hammerite has changed the formula. It's no longer is heat tolerant & turns gold & brown.
Rob McCool
71
13
Birkenhead
I haven't got any pics and didn't know about the formula changing but I'm sure there will be other high temp paints available - shame though as smooth hammerite gives an original look finish to the calipers. ..
altea-ego
176
Heres a picture of my FR calipers I painted. These are brush painted with high temp paint. Done 9000 miles since and still look good. Even the dealer commented on them!
Hubs are painted too to stop them rusting with aluminium high temp paint.
Kirman93
31
I'm thinking of dark blue for mine! I've just purchased the 18" Performane alloys. What colour you done the hub mate?
Aardvark
242
Leeds, Yorkshire
Terrific job!!
I read that you brush painted, do you mind offering more details on how many coats, what product, drying time, painted in situ with pads in or remove pads? How did you degrease before painting, the whole nine yards of best practice please. I would like to do mine what I want them to look right!
concerned cat
497
Huddersfield UK
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Halfords heat resistant satin silver on the hubs & E-tech Gold engine paint on the calipers. Taken just after I did them but still come up like new!
altea-ego
176
Cheers, the calipers were done with e-tech caliper paint. and the hubs with car plan aluminium paint (silver).
altea-ego
176
Terrific job!!
Thanks. heres a quick summary of the process I followed.
Hubs
I got rid of the rust on the hubs with a wire brush drill attachment.
Cleaned with brake cleaner.
Treated with a rust eater.
2 coats of the car plan aluminium heat paint.
This matches the alloys pretty well too.
Callipers
I remove the calliper body to remove the brake pads.
Cleaned it all with brake cleaner.
Painted the calliper with e-tech calliper paint while connected to the brake hose. (this was the tricky part not to mess up) (tip here is to paint the inside first while holding in your palm, then do the outside resting on box/bucket. The carrier was left bolted to the hub. I did 2 coats following the instructions. Left overnight to fully dry then put back together with copper ease on the pad clips.
The reason its looks good is because the pads were removed, would have been harder to do with them in place imo.
altea-ego
176
PS, I did the same process on my Altea back in 2005, and when I sold it in late 2014 they still looked better than a 3 year old car including some of the ones I've seen at main dealers..
