Bulb Sizes
dgmx5
Newbie
Nov 7, 2004
33
Problem with front interior LEDs
I have just bought 2 x 501's and a 42mm LED festoon and fitted them in the front interior roof lining unit. When the door is shut, the rear interior roof lights fade as you would expect after the initial delay but the front ones momentarily flash off and then remain on. Is there any reason why the wouldn't fade?
The front LEDs I have used were bought off ebay from fizzmocouk (ebay links are pretty useless on here for the future as they don't work after 90 days, but links to the items are http://www.ebay.co.uk/itm/290604291747?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 and http://www.ebay.co.uk/itm/290604291747?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649).
TIA
steky
Hopefully get my interior lights changed at the weekend. Great info regarding what bulbs are needed on here.
Leon1600s
Once a 1600, now an LCR
Sep 17, 2011
115
Berkshire
Thanks for the info, really useful and I'm all LED'ed up now.
Only question is with the rear rooflining lights. I've bought the right size (T5) and they fit but they're really dim. I figured this is as they are SMD one and therefore are pointing 90 degrees out from the ideal position. I can't seem to find any 'normal' LED ones so I'm wondering if anyone has modified their buld at all to sort it out? Or maybe point me in the right direction to get some that are more suitable.
Denzil
92
10
South Wales
Rear courtesy / interior T5 lights
Please amend the sticky to read T5 Neo Wedge instead of just T5.
I ordered two T5s, only to realise that I'd wasted money as I bought the wrong bulbs.
To clarify, the rear interior lights in the Seat Leon mark 1 are T5 Neo Wedges.
Den
mark_eisner
157
mark.theeisners.co.uk
You do need the T5 neo wedge bulbs but i managed to modify them.
If you unwrap the wire and pull the bulbs out of the old bulb base can wrap the new bulb contacts around in the same way, even though my T5 bulbs were 3 times as long as the original they still fit. They could still use a better reflector to distribute the light better though.
CH1NNV
May be helpful to others to add to the sticky; but my Leon has clear indicators and requires 581 coloured bulbs, not 382's.
Apr 13, 2020
sol_j
50
7
Hi
I know this is an old thread, but has anyone had issues where the rear dipped beam/ fogs don’t work? I have an issue where the when turning on the headlights it activates the brake lights and the fog light bulb itself doesn’t work
