I have just bought 2 x 501's and a 42mm LED festoon and fitted them in the front interior roof lining unit. When the door is shut, the rear interior roof lights fade as you would expect after the initial delay but the front ones momentarily flash off and then remain on. Is there any reason why the wouldn't fade?
Thanks for the info, really useful and I'm all LED'ed up now.
Only question is with the rear rooflining lights. I've bought the right size (T5) and they fit but they're really dim. I figured this is as they are SMD one and therefore are pointing 90 degrees out from the ideal position. I can't seem to find any 'normal' LED ones so I'm wondering if anyone has modified their buld at all to sort it out? Or maybe point me in the right direction to get some that are more suitable.
You do need the T5 neo wedge bulbs but i managed to modify them.
If you unwrap the wire and pull the bulbs out of the old bulb base can wrap the new bulb contacts around in the same way, even though my T5 bulbs were 3 times as long as the original they still fit. They could still use a better reflector to distribute the light better though.
Hello all, Heppy Easter, i am new in this group and dont be angry on me if somthing wrong, i am looking everywhere my seat light ring and i can not find i am thinking maybe somebody can help me whats the mm lights.
I thinking buy this ring and i dont know the light mm
I know this is an old thread, but has anyone had issues where the rear dipped beam/ fogs don’t work? I have an issue where the when turning on the headlights it activates the brake lights and the fog light bulb itself doesn’t work
