Brake Ballancing Weights AARRGGHHH!!!
cupraRgstar
188
Edinburgh
Alright guys just had the car MOT'd and the wheels needed ballancing so they
put the required weights on the wheel but there is a problem, the alloy
weights are rubbing against the brake callipers which while i dont think this is
causing any damage creates a very annoying rubbing noise. Does anyone
know if these weights will eventually wear away or will i need to have them
moved?again!
mrcoyote
See no evil...
Jul 26, 2004
2,624
If they wear away then your wheels won't be balanced properly, so you might as well get them moved if you can. You should be able to get them moved for free as they should have taken the calipers into account when placing them tbh.
Kevgrady
420
North East
All that will happen is the caliper will get scratched and the weights will more than likely fall off! Take it to your nearest tyre outlet and tell them you want both front "static balancing" ;)
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
generally thinner stick on weights also available, (if) they had them to use.. alternatively, juts move them inboard out of the caliper contact area but in the same position radially.
even the OE seat sport wheels with brembo's would be so close to rub the numbers off the top off the thin weights when i ran them
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
what with lead weights?????:lol:
IIRC they don't use lead anymore. But yeah they are still soft so should wear away. Can you not just go rob some low profile sticky back weights from your local tyre place and just re apply the same weight just a little further in to the wheel and away from the caliper. I'm sure that moving them just out of the way won't do much to harm the balance of your wheels.
EDIT/ Just read your post Bill, beat me to it.
