Brad's poorly LCR
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Following on from This thread, Brad took a trip down to see me today and we plugged my laptop into his car.
Nice to meet you, Brad.:)
First of all, the fault codes on the car were
Code:
VAG-COM Version: Release 409.1-S
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01: Engine
   Controller: 1ML 906 032 A
   Component: 1.8l R4/5VT         0001
   Coding: 10510
   Shop #: WSC 79413
   VSSZZZ1MZ4R083486     SEZ7Z0D2387551
No fault code found.
Readiness: 0000 0101
Address 03: ABS Brakes
   Controller: 8N0 907 379 G
   Component: ESP FRONT MK60      0101
   Coding: 0019469
   Shop #: WSC 00001
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC
   Controller: 1M0 820 043 E
   Component: 1M-CLIMATRONIC    X0702
   Coding: 00041
   Shop #: WSC 06402
Skipping Address 15-Airbags
Address 17: Instruments
   Controller: 1M0 920 922 F
   Component: KOMBI+WEGFAHRSP VDO V05
   Coding: 05424
   Shop #: WSC 00000
1 Fault Found:
            49-10 - No Communications - Intermittent
Address 19: CAN Gateway
   Controller: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 06402
1 Fault Found:
Address 46: Central Conv.
   Controller: 1C0 959 799 F
   Component: A7 Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 06402
Address 56: Radio
   Controller: 1M0 035 186 J
   Component: Radio       GRO    1 24
   Coding: 00403
   Shop #: WSC 06402
1 Fault Found:
00856 - Radio Antenna
            36-10 - Open Circuit - Intermittent
End   --------------------------------------------------------------------------------------------------
I cleared the codes.
I then plugged my SPS3 in to see if we could get any Revo response. It peeped a lot for Revo off, and then peeped a lot when I tried Revo on. (is that what we'd expect on a non-Revoed car???? :shrug: )
We then set off to do some logs. The car has no pull....
Firstly 003 and 020. The car won't rev over 5080 rpm....
Code:
Monday	9	April	2007	11:20:41
1ML 906 032 A		1.8l R4/5VT         0001
Group A:	'003			Group B:	'020
RPM	Mass Flow	Load	Ign. Timing	Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
 /min	 g/s	%	 °BTDC	 CF	 CF	 CF	 CF
3040	8.47	5.9	1.5	0	0	0	0
3080	44.5	27.5	21	0	0	0	0
3160	61.14	27.1	27.8	0	0	0	0
3240	56.22	26.7	27.8	0	0	0	0
3360	58.78	27.5	28.5	0	0	0	0
3480	60.97	27.8	28.5	0	0	0	0
3600	62.22	28.2	28.5	0	0	0	0
3720	65.5	29.4	28.5	0	0	0	0
3840	68.28	29.8	28.5	0	0	0	0
3920	70.25	30.2	28.5	0	0	0	0
4040	70.92	30.6	28.5	0	0	0	0
4160	73.39	30.2	28.5	0	0	0	0
4240	75	30.6	28.5	0	0	0	0
4360	78.47	31	28.5	0	0	0	0
4440	79.11	31.4	28.5	0	0	0	0
4560	80.11	31.8	28.5	0	0	0	0
4640	82.28	32.5	28.5	0	0	0	0
4760	84.75	32.9	28.5	0	0	0	0
4840	86.5	32.9	28.5	0	0	0	0
4960	88.56	33.3	28.5	0	0	0	0
5040	82.06	31	30	0	0	0	0
5080	76.14	28.6	30.8	0	0	0	0
5120	66.19	25.9	32.3	0	0	0	0
5160	61.08	23.9	32.3	0	0	0	0
5160	57.64	23.1	32.3	0	0	0	0
5120	3.86	7.1	34.5	0	0	0	0
5080	12.03	8.2	4.5	0	0	0	0
4960	11.97	8.2	4.5	0	0	0	0
Unspectacular MAF readings - but I don't think that's it......
Next 115 031 .... I am a tit :redface: I can't find the log on my computer. :hide:
Anyway, when I was logging, Requested Boost was sitting solidly at about 1350 ish with Actual following it exactly.
Next 118 and 032
Code:
Monday	9	April	2007	11:24:26
Group A:	'118				Group B:	'032
RPM	Temperature	Load	Absolute Pres.		Lambda	Lambda
				TIME
 /min	°C	%	 mbar	STAMP	%	%
2600	23	0	1080	9.65	0	-8.6
2640	24	72.9	1110	10.35	0	-8.6
2760	24	23.9	1380	11.06	0	-8.6
2880	23	24.3	1350	11.76	0	-8.6
3000	22	21.6	1350	12.46	0	-9.4
3120	22	17.3	1340	13.17	0	-9.4
3240	21	14.5	1340	13.87	0	-9.4
3360	21	9.4	1340	14.68	0	-9.4
3480	21	7.1	1330	15.38	0	-9.4
3560	21	3.1	1330	16.08	0	-9.4
3680	21	0	1340	16.79	0	-9.4
3800	21	0	1340	17.49	0	-9.4
3920	21	0	1340	18.2	0	-9.4
4040	21	0	1350	18.9	0	-9.4
4160	21	0	1340	19.71	0	-9.4
4240	21	0	1350	20.41	0	-9.4
4360	21	0	1350	21.11	0	-9.4
4440	21	0	1360	21.83	0	-9.4
4280	21	0	1190	22.52	0	-9.4
I then did a Vag-Com TB reset. Made no difference.
I checked the car for fault codes again and none came up.
Finally, we tried my good N75F on Brad's car. Made no difference.
Can anyone tell us why the car is only requesting 1350 -ish mb and won't rev over 5080?
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
maf sensor is reading terribly low matey. if its not getting the airflow detected its not going to supply the fuel, hence no revving..
Did you disconnect the maf for a run?
jonathanp
736
Coventry
I would say wastegate but that would show up on the actual vs requested, does sound like a mapping issue
anyone played around with lemmiwinks on there or something similar?
could try a battery disconnect
1350 millibar is really 350 millibar when you take off atmospheric, 5-6 psi maybe?
almost looks like a valet mode, will the car get up to a good speed? 70mph or more?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
That's the thing - Car was allegedly chipped, but may have been 'interfered' with. The car will do just over 5k rpm in any gear, so it's more than a limp mode or valet mode. :shrug:
Brad's tried battery disconnects..
jonathanp
736
Coventry
I think your right it looks like the car is doing exactly what its told to do, hence no real fault codes and no change when components are swapped over
something has either been changed or the car has been reset to limp/valet mode (maybe even a fail safe to protect tampering but I doubt it)
ecu swap will probably confirm everything
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
my SPS beeps, rather than peeps. maybe that's the problem :think: ;) Seriously though, I think that they beep even if they're plugged into a car that's not Revo'd. Is he POSITIVE it's been Revo'd?
The errors maybe point to a dodgy ECU connection, a dodgy ECu or I remember reading somewhere that a ropey soldered in chip gave similar errors.
I would go and see a Revo dealer, see if they can reflash (there might even be any update available) then take it from that.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
No Phil, the only reason Revo was suspected was because a 'mapper' Brad knows had a look - couldn't read the ECU and said last time that had happened it was because Revo was on the car.
Mitchy
TTRS
Oct 12, 2004
2,310
I would say its in a safe/valet mode otherwise requested wouldn't be so low at 0.35bar. Can you turn valet mode off with SPS?
Were you at full throttle when logging MAF? I take it you tried it in 4th gear? Were the lower 3 gears exactly the same with a 5080 limiter?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
There is valet mode on Revo (Boost 0) so on/off won't have changed this I think
You would need to change it to a specific setting (assuming this is the problem) but I'm sure on the Ibiza Valet rev limit was 4000rpm
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
I thought valet mode was rev limited at 4k on the Leons too.... Maybe I should have tried some other Revo settings, but as it was beeping lots more than when in use on mine, I didn't think Revo was on the car.
Bradmax57
77
Newcastle upon Tyne
WOW, what a response! Cheers Dave for you all your help regardless of wether we got it fixed or not, I realised I had a football match to go whilst on way home! Wife was not best pleased, in response to a question above car will still do a ton (i think ;) )
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Worth a try, Brad.
I'm sure this thread will get a bit more input yet. In the meantime, several lines of enquiry.......
Contact the previous owner to find out how the car was mapped / chipped.
Try another MAF
I've PM'd Kev from Revo to ask what happens when you put an SPS3 in a non-revoed car...
Meet me early one evening on the A19 and we could try some other Revo settings...
