Following on from This thread, Brad took a trip down to see me today and we plugged my laptop into his car.
Nice to meet you, Brad.
First of all, the fault codes on the car were
I cleared the codes.
I then plugged my SPS3 in to see if we could get any Revo response. It peeped a lot for Revo off, and then peeped a lot when I tried Revo on. (is that what we'd expect on a non-Revoed car???? )
We then set off to do some logs. The car has no pull....
Firstly 003 and 020. The car won't rev over 5080 rpm....
Unspectacular MAF readings - but I don't think that's it......
Next 115 031 .... I am a tit I can't find the log on my computer.
Anyway, when I was logging, Requested Boost was sitting solidly at about 1350 ish with Actual following it exactly.
Next 118 and 032
I then did a Vag-Com TB reset. Made no difference.
I checked the car for fault codes again and none came up.
Finally, we tried my good N75F on Brad's car. Made no difference.
Can anyone tell us why the car is only requesting 1350 -ish mb and won't rev over 5080?
Code:
VAG-COM Version: Release 409.1-S
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01: Engine
Controller: 1ML 906 032 A
Component: 1.8l R4/5VT 0001
Coding: 10510
Shop #: WSC 79413
VSSZZZ1MZ4R083486 SEZ7Z0D2387551
No fault code found.
Readiness: 0000 0101
Address 03: ABS Brakes
Controller: 8N0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019469
Shop #: WSC 00001
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC
Controller: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00041
Shop #: WSC 06402
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 1M0 920 922 F
Component: KOMBI+WEGFAHRSP VDO V05
Coding: 05424
Shop #: WSC 00000
1 Fault Found:
49-10 - No Communications - Intermittent
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
1 Fault Found:
Address 46: Central Conv.
Controller: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 06402
Address 56: Radio
Controller: 1M0 035 186 J
Component: Radio GRO 1 24
Coding: 00403
Shop #: WSC 06402
1 Fault Found:
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
End --------------------------------------------------------------------------------------------------
Code:
Monday 9 April 2007 11:20:41
1ML 906 032 A 1.8l R4/5VT 0001
Group A: '003 Group B: '020
RPM Mass Flow Load Ign. Timing Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
/min g/s % °BTDC CF CF CF CF
3040 8.47 5.9 1.5 0 0 0 0
3080 44.5 27.5 21 0 0 0 0
3160 61.14 27.1 27.8 0 0 0 0
3240 56.22 26.7 27.8 0 0 0 0
3360 58.78 27.5 28.5 0 0 0 0
3480 60.97 27.8 28.5 0 0 0 0
3600 62.22 28.2 28.5 0 0 0 0
3720 65.5 29.4 28.5 0 0 0 0
3840 68.28 29.8 28.5 0 0 0 0
3920 70.25 30.2 28.5 0 0 0 0
4040 70.92 30.6 28.5 0 0 0 0
4160 73.39 30.2 28.5 0 0 0 0
4240 75 30.6 28.5 0 0 0 0
4360 78.47 31 28.5 0 0 0 0
4440 79.11 31.4 28.5 0 0 0 0
4560 80.11 31.8 28.5 0 0 0 0
4640 82.28 32.5 28.5 0 0 0 0
4760 84.75 32.9 28.5 0 0 0 0
4840 86.5 32.9 28.5 0 0 0 0
4960 88.56 33.3 28.5 0 0 0 0
5040 82.06 31 30 0 0 0 0
5080 76.14 28.6 30.8 0 0 0 0
5120 66.19 25.9 32.3 0 0 0 0
5160 61.08 23.9 32.3 0 0 0 0
5160 57.64 23.1 32.3 0 0 0 0
5120 3.86 7.1 34.5 0 0 0 0
5080 12.03 8.2 4.5 0 0 0 0
4960 11.97 8.2 4.5 0 0 0 0
Next 118 and 032
Code:
Monday 9 April 2007 11:24:26
Group A: '118 Group B: '032
RPM Temperature Load Absolute Pres. Lambda Lambda
TIME
/min °C % mbar STAMP % %
2600 23 0 1080 9.65 0 -8.6
2640 24 72.9 1110 10.35 0 -8.6
2760 24 23.9 1380 11.06 0 -8.6
2880 23 24.3 1350 11.76 0 -8.6
3000 22 21.6 1350 12.46 0 -9.4
3120 22 17.3 1340 13.17 0 -9.4
3240 21 14.5 1340 13.87 0 -9.4
3360 21 9.4 1340 14.68 0 -9.4
3480 21 7.1 1330 15.38 0 -9.4
3560 21 3.1 1330 16.08 0 -9.4
3680 21 0 1340 16.79 0 -9.4
3800 21 0 1340 17.49 0 -9.4
3920 21 0 1340 18.2 0 -9.4
4040 21 0 1350 18.9 0 -9.4
4160 21 0 1340 19.71 0 -9.4
4240 21 0 1350 20.41 0 -9.4
4360 21 0 1350 21.11 0 -9.4
4440 21 0 1360 21.83 0 -9.4
4280 21 0 1190 22.52 0 -9.4
