Boost Pressure Control Valve (N249): Mechanical Malfunction
Mr OCD
1,974
Manchester, UK
Currently...
Mr OCD
1,974
Manchester, UK
As car was with error code...
[/QUOTE]
Pipes checked / tightened / DV cleaned out:
N249 Vac removed (N249 Mod done)
... and I STILL have the fault code... :censored:
Mr OCD
1,974
Manchester, UK
Could be worth a try but wouldn't think it would be too stiff as yours is remapped isn't it? So higher boost and stronger spring needed anyway... Tried stiffer?
What you using for logging btw? VCDS?
Yellow spring should be fine for a remapped car mind ... not sure like idea of stiffer!
Yeah VCDS... :)
Mr OCD
1,974
Manchester, UK
VCDS-Lite Version: Release 1.1
Thursday, 29 November 2012, 20:52:49:50269
Control Module Part Number: 06A 906 032 HN
Component and/or Version: 1.8L R4/5VT 01 0001
Software Coding: 11510
Work Shop Code: WSC 66565
VCID: 7195929A28A7
Additional Info: VSSZZZ1MZ2R047893 SEZ7Z0A1231135
1 Fault Found:
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-00 - -
Aug 27, 2012
581
Maidstone, Kent
Read on a website that someone else had same code and replaced N75 and fixed it... But that was down to him saying it didnt feel right on boost... Seems a tricky one mate
Is your version of VCDS registered? Debating to register mine lol
