Boost Pressure Control Valve (N249): Mechanical Malfunction
Mr OCD
1,974
Manchester, UK
Just scanned the LC with VCDS before doing some logging in a bit and see this code...
Checked visually and see no issues... funny how this code has only popped up after it visited the main dealer for coil packs ... :rolleyes:
Will clear it in a moment and go for drive - any ideas?
Mr OCD
1,974
Manchester, UK
Well logging shows car running well although IAT's of 45degc in this temps is hilarious...
I'm wondering if taking boost gauge off the DV is causing the issue?
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
No you can take the feed from any vacuum point.
It is still connected to the loom under the plate?
Loads of done the delete, I'm sure there will be one flying around.
Mr OCD
1,974
Manchester, UK
Boost Log
Code:
Group A:	'115				Group B:	'031
	Engine Speed	Engine Load	Charge Pressure	Charge Pressure		Lambda Sensor	Lambda Sensor
TIME			(specified Value)	(actual Value)	TIME	Current Value	Specified Value
STAMP	 /min	%	 mbar	 mbar	STAMP
1.43	840	12.8	1000	1010	1.92	0.938	1
2.32	1120	48.1	1000	1010	2.72	0.86	1
3.12	1360	75.2	1120	1050	3.52	1.016	1
3.93	1760	80.5	1340	1180	4.33	0.977	1
4.74	2200	97	1310	1350	5.23	0.961	0.953
5.63	2680	85.7	1150	1350	6.05	0.875	0.945
6.54	2320	13.5	1000	1130	6.94	0.75	0.945
7.34	2080	69.2	1000	1200	7.76	0.899	0.945
8.16	2160	48.1	1000	1110	8.65	0.891	0.938
9.05	2360	107.5	2230	1330	9.45	0.844	0.899
9.87	2760	164.7	2260	2120	10.37	0.899	0.891
10.77	3360	191	2160	2300	11.28	0.891	0.891
11.79	4080	191.7	2110	2360	12.27	0.891	0.891
12.68	4680	182	2020	2220	13.08	0.867	0.867
13.49	5160	170.7	2010	2100	13.92	0.852	0.86
14.38	5600	160.2	1930	1940	14.8	0.844	0.852
15.2	5960	153.4	1880	1860	15.61	0.844	0.852
16.11	6320	145.1	1910	1830	16.51	0.758	0.86
17	5280	16.5	1000	1190	17.44	0.766	0.938
17.94	4720	11.3	1000	1190	18.41	1	1.047
18.83	3120	12.8	1000	1070	19.31	0.75	0.891
19.72	3160	12	1000	1040	20.22	0.899	0.938
20.63	3120	11.3	1000	1030	21.02	0.961	0.938
Mr OCD
1,974
Manchester, UK
Well after mucho discussion it does seem as though the DV could be playing up ... or a possible boost leak ... so that's tonights job :)
If after checking the above still flagging fault then I will bypass the N249 as a test.
milner575
241
hereford
well if the dealer changed the coil packs, they removed the n249 to get them out yeh? so they broke it in other words. sounds about right lol
