best exhuast, induction kit
vwbassett
Joined the Dark Side
Aug 13, 2007
963
53
Surrey
certainly does went through my head so i priced up a tip which would cost in the region of £35-50 with 3 quotes ive got(pipewerx, RSR and another independent) and i can do the welding where i used to work but if it ends up bent which is easy to do as i doubt i could do it in situ it will look even worse than a rusting one.
diirty_dave
thanks for ur help, anyone rate teh pipercross open cone induction kits or teh k&n ones
nicksxjr
Revo....whiplash!
Jul 24, 2009
254
Somerset, taunton
do not use k&n for any vag they ruin the maf!!!!!
friend of mines just spent loads reparing the damage from a k&n!
pipercross make a nice whooosh and perform well
nicksxjr
Revo....whiplash!
Jul 24, 2009
254
Somerset, taunton
his is a lcr 225 went through two mafs in 12 months changed to a green cotton about 8months ago and hasnt played up since.
apprently the oil from the filter sticks to the sensor and ruins it. green cottons and pipercross are not oiled.
vwbassett
Aug 13, 2007
963
53
Surrey
greens are oiled, my panel came pre oiled and when i clean it i re-oil and remove the excess. You need oil as it aids filtering or you will suck up larger crap into the combustion chamber.
adm013
197
Edinburgh
The way you knacker the MAF is by using to much oil, either from the factory or after cleaning yourself, it doesn't need a lot just a very thin film to catch the smaller bits.
