Have you checked your cam chain tensioner? It will make a ticking noise if the chain is loose and hitting off the sides, it should disappear with higher revs though so might not be this, may be worth checking though
Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
check tdc piston heights between the cylinders..
suspect bent rod
