How the hell did you mount that shiftbox again? And yes it does look very good!
Literally turned it upside down yeah? Very race car like lol, even looks good seeing the cables, bet they took some cleaning!
Right does anyone run one if these ?
Is it true that it changes it to a lift up reverse ?
Also can they be fitted from the top? Or do you need to remove the exhaust to fit it ?
Mixed reports here then ! I know it will be tight as with the golf it was like key hole surgery with a flat bladed screwdriver
Mine won't go into reverse without me holding the arm down
Going back to normal gear shifter
What arm? are you sure you have adjusted the stopper correctly?
