b1nuzz
271
Bristol
Hi All,
Quick question,
Quite fancy having the following fitted;
Auto Window Brite
so that my lights stay on when i get out the car.
I have done a search on it but all the threads on it dont really answer the questions I have.
Can you fit this unit standalone, or do you need another Auto Window unit as well?
Has anyone got one of these? Are they easy to fit?
They look like a good idea.
Hi, I have this fitted to my LCR, its actually two in one, if that makes any sense. You get the window module with the light function built in. So you can do all the open and closing windows from the key fob, and also when you open close the locks on the car it puts the lights on when unlocking and locking the car. It has i light sensor included so that the lights side of thing only operated in dim/night conditions.
Fitting involved taking the door card off and feeding a couple of wires through the conduit from the door to the fuse panel. You also have to tap into other wires with the kit supplied. Instruction are pretty good and detailed, took about a half hour 45 mins to do.
Andy
OK nice. Looks like i might be giving that a go then soon.
I already have the windows bit, but the lights would be wicked.
Ben
