Auq to bam conversion
liamgill
I'm doing an auq to bam conversion and I coming up with so many little differences between them all the time! Anyways today I'm swapping the loom over that I bought from a cupra r with a bam engine fitted but it doesn't have the "100 relay fitted" I'm just wondering what it does and what will I have to do to sort it. Or will I not need it?
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,250
1,107
Kent
Im pretty sure that's for the SAI which the BAM & AMK engines don't have.
Sent from my SM-G986B using Tapatalk
Reactions: mty12345
Thai-wronghorse
Dec 3, 2015
2,250
1,107
Kent
That relay is also used for the glow plugs on the TDI variants as well.
Thai-wronghorse
Dec 3, 2015
2,250
1,107
Kent
On my engine I did away with that relay box and tucked the 428 relay into the plastic harness channel to the side of its original location.
liamgill
Nice 1 cheers. I'm coming up with the twin intercooler problems now think I need to buy the correct brackets for them or do away with them and go fmic which I then may run into fitting the cupra front bumper problems 🤔
Thai-wronghorse
Dec 3, 2015
2,250
1,107
Kent
A front mount intercooler is better but if you needed chassis rail mounting brackets for the twin side mounts then I have them here mate.
