Been a very long day so gonna keep it fairly short as I am going to collapse into the sofa...
First of all the N75 pipe blew (sure it was tight) which threw us for a bit then VAGCOM was reporting requested and actual boost of around 1.5bar but my boost gauge was only showing 1bar so changed the MAP sensor to see if that was the prob and it wasn't... check for obvious boost leaks but couldn't find any so will look properly when I can. Might be the actuator being problematic or maybe the N75... will look into this and see if I can find the missing half a bar of boost...
After a few logging runs, it became evident that the injectors were getting near to being on all the time... we hit 20ms on time when 22/23ms is just on.... looking at a 4bar FPR I think to give me some overhead.
Anyhoo... settled on 1 bar of boost for now until I can find out what the prob is and did some runs...
383bhp and 326ftlbs torques....
Both curves are as smooth as you like with power climbing on boost from around 3600rpm to peak at 6600rpm, torque climbing from a similar figure to a peak at 5500rpm.
Car feels very nice to drive now...
EGT's are a bit of a
problem getting a little high... changing the exhaust should
help keep them in check and I won't be looking for more boost just yet as they will get worse and cause probs.
Considering how much power she is producing on just 1 bar of boost, there isn't much I need to do to get 400bhp so I will look at making a few tweaks to sort any potential reliability issues out and then tweak the boost up a bit.
The extra boost will of course give me more torque so at least while its a little on the low side my clutch will last a bit longer ;P
<tuffty/>
