Any Sparkies able to give some advice ?
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
I need to put up two external 15-20 watt led pir floodlights , I have already done one as it was over the garage and was able to use a very short run of 1.5mm white flex, however the other one needs to go over the front entrance way , there is no access back into the house and the area it needs to be mounted to is upvc cladding.
The closest power is in the garage (no more than 10mtrs max) , I dont want to use black cable (all that seems available) as the cladding wont support conduit. What options (if any) do I have ?
RADIOTWO
514
98
North Derbyshire
Hi Gokiwi64
I am not sure what the problem is, 1st you can get white flex, but you say the cladding wont support conduit, but just put some sticky back mini trunking and run the cable through it
https://www.screwfix.com/p/nexans-round-flex-2183y-3-core-0-75mm-x-10m-white/1387t
And you can get this in 3mt lengths
https://www.screwfix.com/p/tower-self-adhesive-mini-trunking-12mm-x-8mm-x-2m/73354
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
I've not seen any external or outside rated white flex , everything with that rating is black in colour, Ill look a bit harder.
No idea why I didnt think of self adhesive trunking !!
The cladding is like maybe 8mm thick with a hard outer shell but a foam inner , it doesnt lend to being screwed into unfortunately.
I
RADIOTWO
514
98
North Derbyshire
I
I don't think there is such a thing as outside rated flex, well not for what you need, if it was going under ground etc but going in trunking it will be fine, also if it is staying up there I would still put some small self tappers in through the back of the trunking into the cladding
