hi
any more feed back o the HU ?
is your car pre facelift if so what did you do regarding the facia
Car is pre-facelift and the official RNS sat nav facia fits most android units perfectly (theres also an official square cornered facia for double din stereo units).
The unit itself is well enough made, although an extremely tight fit, depth wise - it took several attempts to tuck away the cabling sufficiently to get the unit flush. The cabling is all labelled and pretty self explanatory and theres a handy couple of 12v ignition power cables feeding our from the unit to hook up any additional devices you might fancy, amp, reverse cam, etc. The pure android os is fast and Ive not had any hanging using the stock apps - ive not bothered installing much on it yet.
The screen is nice and bright and has something of a tactile touch. My one criticism is that its fairly reflective and, combined with the units low position on the dash, this can make it difficult to see at times, especially when trying to navigate wearing sun glasses!
Bluetooth connectivity works well - I can play music from my (android) phone and start/stop/skip tracks directly from the unit. I can't find a way to change album though without going to the phone. The unit has sync'd all my contacts so I can call directly from it and call quality is decent.
Sound quality in general is fine. I'm running stock speakers and no amp and Ive not noticed any change in quality. Radio reception is slightly weaker, even with supplied signal booster, I guess because it doesn't utilise the dual aerial.
Overall I am delighted with the unit. It looks really pro when fitted and livens up the otherwise dull dashboard. Im using a USB pendrive attached in the glovebox for all my music and the phone connects automatically every time I get in the car.
My biggest criticism so far is that there's no dedicated volume control on the front of the unit. I have to drag down from the top of the screen and press the volume shortcut. Not ideal. Admittedly, I can use the steering wheel controls and will try downloading a volume app from playstore.
Will post pics when I reach 15 posts
