Alternator belt tensioner
peter.s
45
Is the tensioner for the alternator belt adjustable? Or is it supposed to be self adjusting?
I've just the alternator belt replaced in my 1.9 TDi - but now the tensioner is rattling like crazy. Not sure if I can adjust it or if I need to replace it. Any advice welcome...
peter.s
45
They didn't install a new alt, just a new belt.
I had my water pump and timing belt replaced, and while they were at it they put in a new alt belt. Now I'm left with this problem.
sockpuppet
837
When I had my tensioner fitted it would rattle for the first 10 seconds on startup and then it was quiet. If it is definitely the tensioner rattling you can get a replacement for about £30, I would recommend getting a genuine one.
There is a common fault where the alernator clutch pulley goes and this will cause a vibration on tick over and makes the tensioner bounce about.
