another mega annoyance dealt with today!!! since i got the car its had a pikey fix on the fuse box as a previous owner appears to have left a ****ed fan fuse in the fuse holder for ages resulting in it melting a bit so someone has routed wires out the fuse box and the fan fuse has been on display in the engine bay!! SO got a fuse box out of a smashed 1.4 leon a few weeks back from my mate whos dad owns a recovery company, the main connection looked similair so took it on the off chance it would fit as i got it for nothing anyway.
had to do a bit of modification to make it all fit and work but well worth it in my opinion looks far far faaaaaar tidier now
so started off by removing the old fuse box and checking the new one fits
from here you can see what i would need to modify, i.e drill out the blanks for the 3rd and 5th wires so they could be wired up and also cut a groove for the wires to rest in and so the box can be closed correctly as it was designed without the 3rd and 5th wires being needed.
the old fuse box
can see here the differences between the 2 boxes clearer.
so onto the mofifying!
started by splitting the old fuse box to bits so i could use the parts needed to make the new box function as it should. got my dad to hold it open so i could take the pictures as he was helpin me (hes a marine engineer so knows more than i do
i then split apart the old fuse box to add the necessary parts
as you can see its missing 4 nuts for the connections!
added the parts like so
drilled out the blanks and added the inserts
forgot to take a picture showing the blanks
