OLD alarm thread alive again...
Update car been into dealers with no obvious causes found - they have contacted Seat Technical for a prosed solution. Anyone suffered similarly (no doors shown as open or interior lights on) and what was the solution?
Sorry to dig out such an old thread but my FR TDI alarm started to go off on Friday night, and has done so ever since every half hour - couple of hours. No matter what i do it just keeps coming back. It appears to tie in with rain etc, or just coincidence perhaps.
Tried scanning with my chinese VAG COM cable, but now this does not want to work either as i cant seem to read modules that i have previously played with before. The wife says its my fault as i have switched on the beep when lock etc (cant view this module now) but i know thats bull.
Anyway, has anyone recently suffered from random alarm issues and what was replced to sort it out? Just asking as ill struggle to get to a dealership this week...
ta
D
edit: VAG COM FAULT SCAN ADDED BELOW. Any advice on the driver door central locking faults appreciated. Looks like it is the culprit... My lock for back door elec windows has also been faulty for ages, wont go to unlock position... No fault detected though.
VAG-COM Version: Release 704.1
Data version: 20070422
Sunday,16,May,2010,17:51:22:46862
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: ??? Mileage: 95350km/59247miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 03G 906 018 DT HW: 03G 906 018 DT
Component: R4 2.0l PPD1.2 G 0066
Coding: 0050072
Shop #: WSC 66565
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Coding: 0006786
Shop #: WSC 06441
Address 08: Auto HVAC Labels: 1K0-907-044.LBL
Part No: 1P0 907 044
Component: ClimatronicPQ35 008 0303
Address 09: Cent. Elect. Labels: 3C0-937-049.LBL
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Coding: A1880F2F00041000001D00000000000000007F075C
Shop #: WSC 00829
Part No: 1P0 955 119 A
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 00829
Address 15: Airbags Labels: 3C0-909-605.LBL
Part No SW: 3C0 909 605 H HW: 3C0 909 605 H
Component: R5 AIRBAG VW8 027 2521
Coding: 0021045
Shop #: WSC 06441
Address 16: Steering wheel Labels: 1K0-953-549.LBL
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 634 0070
Coding: 0002042
Shop #: WSC 06441
Part No: XXXXXXXXXXX
Component: E0221 005 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.LBL
Part No: 1P0 920 925 A
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0000401
Shop #: WSC 01159
Address 19: CAN Gateway Labels: 1K0-907-530.LBL
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Coding: 3D3F034007000203
Shop #: WSC 06441
Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
Component: IMMO VO3 0422
Address 42: Door Elect, Driver Labels: None
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1118
Coding: 0000688
Shop #: WSC 06441
4 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 0 km
Time Indication: 0
01552 - Motor for Central Locking; Drivers Door (V56); Lock
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 8
Mileage: 0 km
Time Indication: 0
00096 - Drivers Door Central Locking (Safe) Motor (V161)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 8
Mileage: 0 km
Time Indication: 0
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 0 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.142 H07 1806
Address 46: Central Conv. Labels: 1K0-959-433-46.LBL
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Coding: 188000005283CC7F00060D0D6008DF86107C80
Shop #: WSC 06441
Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 06441
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: None
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1118
Coding: 0000688
Shop #: WSC 06441
Address 56: Radio
Cannot be reached
Address 62: Door,Rear Left Labels: None
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1105
Coding: 0000144
Shop #: WSC 06441
Address 72: Door, Rear Right Labels: None
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1105
Coding: 0000144
Shop #: WSC 06441
End --------------------------------------------------------------------------------------------------
