Air Filter In Front Arch?
hadz
286
West Sussex
i was just wondering if any 1 has moved there air filter or induction kit down into the front arch so that it does not draw alot of hot air in?
i have managed to do this using a carbon fibre bit of pipe meant for a golf that has put the filter on the inside of the arch linner!
has any1 else has a go? Pics would be good if you have!:confused: :confused:
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Regular Cone filter can go down there.... some of that area is blanked off by SMIC ducting... so remove the fog lamp to get an air feed, or leave it as it is to find air from somewhere. When braking heavily this area also gets hot and the SMIC is under there which also give up some heat
