I fitted my ipod into the glovebox.
I ran the cables through the back of the gloebox and into the aura hu.
I had to get a hole cut out in the back of the glovebox so I heated up a bit of copper pipe and burnt it through.
You will need to take out the glovebox (torx head drivers). You will need to take off the panel on the passenger side of the dash (open pass door and you'll see the panel with a sort of triangle pointing to were to open it from).
Theres 1 torx screw at the bottom right of the glovebox in the pass footwell.
There is also 3 or 4 torx scews at the top of the glovebox that need taking out (open the glovebox and you'll see them). You'll need a stumpy torx driver for them or a short torx driver.
You will also need to take the HU out so you can plug the ipod connection in.
Put it all back together and voila! job done.
All your cables will be out of sight and it'll look standard.
