Coldside update
So before i go off to get the ko3s dialled in at monster motorsport i thought id have a go at doing the DV coldside relocation.
With some useful info from Berg i managed to get hold of all the parts i needed without having to pay nearly 3 times as much for the forge stuff!
Heres all the stuff on my floor, the blue should tart up the engine bay a bit too
Old pipes and clips out, plus some nasty gunk on old pipes!
standard hose clamps are a pain to get off in tight spaces girly hands required plus 50 layers of skin...
Once old pipes are out the way its time to think about what order and what trimming needs doing to do the new hosing. I began at the bottom and worked up at first. 1st mistake was tightening jubilee clips without making sure it lined up so kept having to undo them again.
Best method if i was doing it again would probably be too try and match new hoses to the shape of old hose and trim and position to suit then slide it back onto car.
heres it coming along...
After a few broken clips and some painful hands later its getting there, while i had the inlet pipe off i had access to the pipe that joins the charge pipe at the front of the engine so switched that for a sexy blue pipe too.
Once the pipes are on from inlet down to map sensor tube down right down behind radiator fan etc the rest is far easier so moving the DV it self and using the flexi tube is piss so done in minutes.
Final result looks something like this...
Hoses popped off a few times but repositioned some clamps/clips seems ok now.
Will find out if they stay on 2moro when i go back to the mapper for my adjustment!
Adam
