by KR cams I'm guessing that means that they're cams taken from a KR engine which is a 1.8 16v as fitted to mk2 golf gti's and corrado's. If this is what they are then there is no benefit whatsoever in fitting them! what is quite common is when poeple have a 9A engined car (late 2.0L 16v corrados ect) that only has 130 odd bhp, then fitting a set of cams from an ABF (or KR, can't actually remember) will give a 20bhp gain taking power to 150bhp.
apparently if you get the cams from the abf golf engine, it will give you a 10 bhp increase ( i think its the ABF i could be wrong)
KR cams are said to bring the power in around 1k rpm earlier but its a trade off in top end.
you can get cams for the 16v from Piper Cams, Kent cams, Shrick, Cat Cams to name a few...
You must be thinking of the 8v fella! if you fit a mk2 golf (PB engined) gti 8v camshaft into an AGG engine it will give up to a 10bhp increse depending on other mods.
I think he did both IIRC
