21psi????
carlos200
117
right, this has happened a couple of times now, and regardless of how nice it is to say that ma ibiza can boost at 21 psi, i am concerned at what this is doing to the turbo..
i had a boost guage fitted about 2 weeks ago, 1st n 2nd gear, boosts about 12-14psi, 3rd and 4th about 14-17psi and 5th anywhere between 12 and 21psi..
although in 5th, it was only boosting as high as 21 as soon as i changed gear, it did still run at 18-19psi afterwards...
also, i have noticed that occassionally at 2-3k revs in 3rd or 4th, under load, it boosts at ~14psi, then vacuums -20, then boosts again, could this be a boost leak?
my VAGCOM doesn't like ma laptop, anyone offer any advise?
:shrug:
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
try to monitor the boost gauge as safely as possible and you'll see that it drops off to anywhere between 10-15psi very soon after spiking to 21ish. so no need to worry, presuming you still have the stock turbo, they only cost about 50quid anyway but loads of people have this and its fine
B3NPM_Cupra
Money = Power!
Dec 9, 2006
262
Tamworth (West Mids)
im guessing you have a remap? if so then 21 psi is fine....mine can spike at 24 psi at times and mostly 21/22 psi. as for the erratic boost this could well be your n75 valve!
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
My k03s revo stg2 peaks around 21psi then slowy drops off 14psi at the redline and holds it there, is that right?
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
You running K03s? IIRC Nicks was running around 26psi and his turbo went pop!
Anbody know what happend to nick?
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
My K03s Ibiza Stage II peaks 20/21 and holds 16/17....
26 PSI is quite high for a standard turbo? What map and timing settings do you run?
Only running 26PSI on the IHI....
Mike
Rik N.I.
249bhp 300lbs Torque
Jun 3, 2007
97
Lisburn N.Ireland
Its a customer jabba map and timing is advanced quite alot not sure on the figures tho
I will double check it, Gauage only goes up to 21psi I'm estimating by how much the needle goes past 21
Rik N.I.
Jun 3, 2007
97
Lisburn N.Ireland
You's know better than me prob, but boost gauge is definitely 24-26
But 250 Bhp and 300Lbs of torque from a k03s means it needs to be boosting high
That torque figure is extremely high
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
Ah righto, I got ya...
If you have a Halfords near by, they do a cheapo £20 30psi and vac gauge. Might be worth getting it to find out, then keep as a spare? lol
Mike
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
The torque figure is a bit higher than i would expect, but then so is the BHP on a K03s?
Mike
Nov 2, 2004
9,335
South Wales
I cant see it holding 16/17psi @ redline either more like 13/14 max.
Its a stupid small turbo so will never hold boost that long without seriously effecting the longevity of it.
