18" wheels on an ibiza
stevie.w
182bhp 297lb/ft
May 26, 2006
45
COOKSTOWN N.IRELAND
yeah you need 7.5 width with the 18s, i had no bother getting these, if you go for 8s youll loose full lock and suffer from a lot of rubbing in the corners
BeEzA
109
Irvine, Scotland
i have leon cupra r 18's on mine and lowered it 40 mm. i had to take all the inner arches out and it still rubs when hittin bumps/ extremely tight corners. will post pics later
pine
76
Finland
195/55 15" has 2% difference on radius versus 215/35 18"(radius is about 0.3 inches bigger). My speedometer was about 2-3% off at 100km/h, now it's only 1% off with 215/40 17"s.
ChrisBowe82
I dont have a beezer, but changing from 14" steely's to 17" alloys didn't affect the speedo on me pug as it matches 100% with what the GPS is telling me. May be just lucky though. One thing I did notice was that it "felt" ie not on the speedo, that it accelerated slower on 17's. But one thing is for sure, and that is the top speed is lower with bigger wheels I know it shouldnt be but it is! (maybe coz rubber is 1/3 wider?? therefore more drag??) proved by going back to smaller wheels for a week and top end going higher :)
muddyboots
Still hanging around
Oct 16, 2002
5,739
That's because with larger wheels, the majority of the wheel weight is further from the centre, and is therefore the wheel is harder to turn.
mrcoyote
See no evil...
Jul 26, 2004
2,624
Also you generally have more metal to move around so the unsprung mass is greater and hence blunts the accelleration a bit.
BeEzA
109
Irvine, Scotland
sorry meant to post pics but just had my exhaust done and dont have any mesh on my back bumper (had bodykit done too) got my mesh this morning so will post pics when its on :)
pine
76
Finland
Buy lighter wheels, OZ super/ultraleggera, TeamDynamics ProRace series, etc., then you won't have slowing issues 'cause of added weight. My 17" TD prorace 2's weight about the as my stock tdi sport's 15" (both with tire).
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
driveshafts will also be under alot of stress too by enlarging the wheel circumfrance. if you enlarge the wheels car would need to be lowered imo as it will make gap between arch and tyre greater. go for sum flashy 16" would look good
ibizasport16v
217
Clydebank
i dont see the point in changing alloys for the sake of an inch or no increase in size as rashcupra suggested, the ones on the sport aint that bad.... and the ones off the r32 golf will be too wide
ibizasport16v
217
Clydebank
make sure the width of the wheel is less than 8. As i had rs4 genuine wheels on mines and tyres where catching front wings.
Either that u put a very low profile tyre on it.
I had 224/40/18.
So i'd go for 7.5 width on an 18 wheel which could be hard to find
aye they are 8's but look there
tommmineh
1.2 POWER
Feb 28, 2005
721
Sheffield/Rotherham
Depends what offset the 8s are
I've got 17 x 8 et 35, 205/40/17 tyres which give a slight streched look, no rubbing at all on std suspension. i think you'd get away with 215/40s tho
the rs4's are prob a lower offset
ibizasport16v
217
Clydebank
thinking more and more about it might just go for 17's when the tyres run out on the standard rims (got a lifetime done about 1010 miles :( )
and thinking about either :
or
