VAG-COM Version: Release 311.2-N
Control Module Part Number: 038 906 019 DQ
Component and/or Version: 1,9l R4 EDC 0000SG 1536
Software Coding: 00002
Work Shop Code: WSC 06402
Additional Info: VSSZZZ6LZ3R163506 SEZAZ0B2630179
1 Fault Found:
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-00 -
this code appeared on a friends ibiza mk4 , can anyone shed any light , car is hard to start when cold , but once running is fine (remapped-not switchable) problem arised 2 weeks after software change , so probably not a software issue , and when warm started , fires first time , few other codes appeared but not in engine 01 group ,
i understand the speed sensor uses data from a toothed wheel on the flywheel when starting , is this sensor on the belt side or g.box side ,
any ideas on a remedy ( new sensor) had a look today and couldnt see it ( plastic cover)
thanks for reading as always
stephen
1 Fault Found:
P0322 - 35-00 -
stephen
