How much do these kits cost though and can they be removed with no trace?
Well you have to drill a hole in the pipe leading to the throttle body!
Up to you, I wouldnt let any of the above issues sway your decision. how long would you keep the car for if you kept it?
Might as well keep it, if you want to...
Why would you need water meth?
you could always buy yourself a second IC/TB pipe, i doubt they will be that expensive TBH, maybe you could even get a secon hand one.So basically, you could not remove it with no trace of it being there then? Just thinking about how one might explain this to a potential buyer come resale time.
Saying that the boost comes on in the k03 substantially sooner than what your turbo will do, so ill prob be driving on boost much more often than you will be, and benefit from a bit better economy.not sure about that because the pmup is only firing when your on a decent boost level anyway. Depends how much you put your foot down really.
huh?
