Bought a brand new set of front and rear discs and pads for my 05 1.9tdi stylance, started fitting today, rears all done before lunch, but when box opened for fronts the discs were only 280mm and the pads all had three pronged clips attached. My discs are 288mm and only the inboard fronts have the three pronged clips which push into the hollow piston. I've seen loads of threads etc which say the 2.0 tdi has 288mm front discs, but my 1.9 has them, anyone else had this ? Another trip back to supplier in the morning to get them changed.
Just for info if anyone is doing disc changes, the torx screw in the disc is a T30, but if it's corroded in place be careful as it's easy to damage.
