1.4 strut brace fitting guide
May 31, 2008
1,247
Hi guys, so i fitted my OMP strut brace to my 1.4s, it was a strut brace for the GTi but it fits any model. I thought i would put a quick guide up to show you how simple and easy it is to do.
So first i got the strut brace out the box and placed it roughly where i wanted it (on the car, not the ground. i didnt take a pic of it roughly on the car)
Once i placed it where i wanted it i took the screenwash bottle off and the clips that hold some of the pipes off. You will need a hacksaw to cut some bolts off. I had to cut the 2 bolts off that support the top of the screenwash bottle mount but this is not a problem as it supported well without them. I also had to cut the bolts off the other strut.
Once these little sticky out bolts were cut off i used a file to file them down so they were level.
After everything was level i put the strut brace back on to see what it looked like.
Once this was done, i got a 4mm drill bit and started to drill some pilot holes, keeping the strut brace on when drilling the holes helps. Once all the pilot holes were drilled i then advanced to a 5 mm drill bit and re drilled the holes and then onto a 5.5mm drill bit.
I then just put the bolts in and did them up tight, but not mega tight :)
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
You had to cut bolts off each side?? I didnt have too. There was a hole in the strut brace in the passenger side of it for the bolt to go through and if I remember correctly there wasnt one on the drivers side.
Did you have to move the expansion tank a little?? Mine had to be moved ever so slightly. Oh you will have fun trying to get the airbox out now with the strut brace, its akward but you can just get it lifted up enough to just clear the throttle body and slide out from underneath the strut brace.
EnGbudd, what do you use to clean your engine cover and airbox to get it as black and shiney as that??
May 31, 2008
1,247
Yeah i had little bolts all over the show, i didnt have to move the expansion tank at all. i used some silicone spray on the airbox and engine cover :) comes up lovely.
May 31, 2008
1,247
I just didnt put them in really really tight, i only did them up till i had to use a bit of force. They seem ok. Its not going anywhere.
I can see results, when cornering quickly i can feel a bit of a difference :)
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
i bolted mine dont know what size, but i agree the soft self tappers supplied arent going to be much good if you hit a track, but for day to day mcdonald runs they are fine.
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
stu did you drill all the way through and use nuts on the other side or tap the strut top?
Think i should be investing in one of these and wouldnt trust a 5mm bolt to hold it in place to be honest
Nut in the underneath, you can get to the nuts in the top of the turrets if you have coilovers if not you'll have to drop the struts
kkcupra
do you need to jack car up for either front or rear upper strut and are these m8 bolts alot better im fitting my front and rear on satuarday !!! :confused:
Ieuan-J
434
South Wales
What engine EnGbudd? coz my engine doesnt look like that... i dont have an engine cover and your manifold heat shield looks much nicer then mine aswel... ive gota 1.4 AEX.
CraigW
Craig.
Apr 12, 2007
4,607
Its an APQ I think, the same as my one. I have the engine cover on mine. You could fit an engine cover though if you found one.
I think he painted the manifold heat shield because he did the rocker cover at the same time.
Ieuan-J
434
South Wales
i found a cover on ebay... buh its a bit much 4 a piece of used plastic.... i wana get a new manifold heatshield and paint it black... and paint my rocker cover blue... :)
