Hi guys, so i fitted my OMP strut brace to my 1.4s, it was a strut brace for the GTi but it fits any model. I thought i would put a quick guide up to show you how simple and easy it is to do.
So first i got the strut brace out the box and placed it roughly where i wanted it (on the car, not the ground. i didnt take a pic of it roughly on the car)
Once i placed it where i wanted it i took the screenwash bottle off and the clips that hold some of the pipes off. You will need a hacksaw to cut some bolts off. I had to cut the 2 bolts off that support the top of the screenwash bottle mount but this is not a problem as it supported well without them. I also had to cut the bolts off the other strut.
Once these little sticky out bolts were cut off i used a file to file them down so they were level.
After everything was level i put the strut brace back on to see what it looked like.
Once this was done, i got a 4mm drill bit and started to drill some pilot holes, keeping the strut brace on when drilling the holes helps. Once all the pilot holes were drilled i then advanced to a 5 mm drill bit and re drilled the holes and then onto a 5.5mm drill bit.
I then just put the bolts in and did them up tight, but not mega tight
