Gotanubeeza
I have had my 1st Ibiza for about a month now and I have a couple of annoying faults.
1) If you give it a short run (less than 15 Mins) then turn off, it will only restart by towing. Starter motors spins fine for ages, but no lift off!!. I have noticed, while its cranking, the odometer reads "ln 02" - is this a fault code?
If you run it for more than 15 mins, no problems.
2) The heater blows cold - Not a good time for that kind of fault!! It was working fine two days ago on the way to work. On the way home all blow, no hot!! The fan is going fine, the hot/cold dial 'feels' fine, you can hear the flap moving through the vents, if you sqeeze the hozes running to the matrix they feel like they are full of water and the header tank sloshes in time with the squashes. WTF is going on?!?!?
Any help gratefully received, thanks.
