1/4 mile ?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
warm it up to somewhere near safely useable but not so hot the fans come on and cool it off mind as that's when the heat 'soaks' in but lift bonnet and push it in the Queue instead will be better
warren_cox
Back from the dead
not agreeing or disagreeing with this as i've turned mine off in queue before. i cannot remember who (may of been the wise Viking) said that you should keep the engine running. reason being when the engine is off the coolant isn't being pumped around the engine. (i understand the lcr has a turbo cooling pump when the engine is off, does it pump to engine aswell?)
makes sense as coolant would bring the temp down quicker than turning it off would it not? obviously to a certain degree, as the OP will be stop starting 10+times in a queue.
I think if you've been there a while and the engine has cooled down a bit then it's not so bad not to leave it running. I suppose the heatsoak only really kicks in excessively when you're on boost. Bit of a catch 22, as I guess you need oil pressure/temp up and running to stop any failures.
With respect to the ECU comment above, I was under the impression that as the ECU builds up 'parameter' it can cause the car to slow down (there are some threads on this quite some years back - circa 2003/4, where cars were running far better when they weren't having to account for the build up of data on the ECU). Knowledge improves and things evolve, so I stand to be corrected, but from what I have read / am lead to believe it should be the case.
Mar 29, 2007
1,207
Berkshire
Blipping throttle on an up-change isn't necessary as the next gear will be spinning more slowly. It's on a down-change that you need to do this...
Lodgey180
WoOoOoOsShH
May 3, 2008
1,046
Middlesbrough
www.mootr.co.uk
oh cool thanks for the advise.. i have reset the ecu by discconnecting the battery before and it did seem to run better.
as far as pushing it to the line i dont want to look like im running big power the limp up then track haha
i can understand big power cars doing that mind
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
why not try all 3 at once then the spanish duo can block him out :):) he wouldn't expect that :):)
smash
Civic is going to beat the ibiza and the leon, its just a hundred times easier to put the power down, and thats what its all about over a quarter of a mile. It doesnt really matter about torque and turbos over that distance if it was a rolling start, then the civic would lose obviously. I think if the turbo cars get a perfect launch then it will be close but still wont beat the civic especially the championship edition one ure racing.
CupraUK
Pushing on
Aug 15, 2005
1,350
Bedfordshire
I totally disagree with this approach unless you have enough time/miles to get a decent level of high power adaption before your 1/4 run (100 miles or so).
As I disconnect my battery each week on a Sunday night and then reconnect the next Saturday because it goes flat otherwise, I can tell you 100% that it runs crap until adaption has made the difference and knows that beans are your flavour. I could not out run a tractor in the first 20 miles on a Saturday.
Maybe its just a Revo thing though
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
i would stip as much fat out as possible, how easy are the front seats to swap in and out , the fiesta was 4 bolts unclip and out , i know the airbag light wud be on , but if reconnected would it not reset itself ??
def the spare and back lot tho
optimax & octane booster is that possible, i know the dirty dervs do it with millers ,
Andrewcupra TDI
Apr 30, 2008
3,282
cant you borrow someones revo sps thinngy to load a map ir is it for one car only etc
or ask the revo man for a trial again this time youl advertise for hime with stickers hand out business cards etc , not your fault you forgot them on the day HA HA!!! (if you want to be discrete ) or hand them out if you want to show its mapped etc
