warm it up to somewhere near safely useable but not so hot the fans come on and cool it off mind as that's when the heat 'soaks' in but lift bonnet and push it in the Queue instead will be better
not agreeing or disagreeing with this as i've turned mine off in queue before. i cannot remember who (may of been the wise Viking) said that you should keep the engine running. reason being when the engine is off the coolant isn't being pumped around the engine. (i understand the lcr has a turbo cooling pump when the engine is off, does it pump to engine aswell?)
makes sense as coolant would bring the temp down quicker than turning it off would it not? obviously to a certain degree, as the OP will be stop starting 10+times in a queue.
why not try all 3 at once then the spanish TRIO can block him out he wouldn't expect that
^^ hahaha ^^
i have reset the ecu by discconnecting the battery before and it did seem to run better.
hi fella try flat shifting the leon i used to do it in mine is it the end of august holiday that you are going to york if so which day sun or mon!
we're going down monday
HMMM well i thought it was the sunday.. couldn't make the monday so never went. think a few went down. should of gone as i got my remap done on sat morning haha
i was there on the sunday it was very busy but there was some quick cars there i matched my pb of 13.1@110
beat my best 1/4 mile time at the weekend i managed a 12.6@112 and it also did a 0-60 time of 4.3 seconds!
