01314 engine control module
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
right was on my way shopping put my foot down was at 6000 revs then the car hesitated lost boost then came back, drove on further and the traction light come on then about 10 mins later the engine managment come on, got home checked on vagcom
16486 maf (G70) signal to low
01314 engine control module 79-00 please check faullt codes
the last code will not clear with vagcom and traction light is on all the time
new ecu is it?????????????????????????
any help will be much apprciated!!
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
01314 - Engine Control Module: No Communications
Possible Causes
* CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
* Fault(s) stored in Engine Control Module
Possible Solutions
* Check CAN-Databus Wiring/Connectors from/to Engine Control Module
* Check Measuring Value Blocks (MVB)
o Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
01314 - Engine Control Module: Check DTC Memory
Possible Causes
Possible Solutions
* Check Engine Control Module for Fault Codes
Special Notes
* Engine Control Module stored a Code which influences other Control Modules Functionality
I'd try a new Maf, clear the code and then see if the other one will clear.
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
the car seems to boost as normal though will i be able to see if maf is goosed by looking at the g/s readings, and what readings should i be seeing if its ok???or goosed???
Feb 25, 2007
1,068
cheshire
g/s whlist driving they should be within 200 of each of otheri think, sometimes when your maf is buggered it still boosts fine
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
I must admit I haven't seen that before, but it's saying the engine module has a fault code and the ecu is going to be stroppy until you fix what's causing that code. :D
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
well did a mass air flow check toady, block 02 and the maf is reading nothing all through the rev range so maf is goosed, hopefully because this is a hard fault this is whats causing my 01314 code!!
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
right bought a new maf today and have horrible boost issues sometimes its there sometimes it isnt, when i blip the trottle there is a hesitation and it hesitates through the rev rage as well, u/s on fit maf is this and whats the comeback on this with gsf???
t17chy
Modifier
Mar 10, 2011
124
Shefford, Beds
i had both these codes last week after putting 2 bosch units on the first being faulty both codes cleared and so did traction control light after a working maf sensor was fitted
CAL LOOK 58
Usefull info, my LC has the same two codes and sounds like it was triggered in the same way you describe (foot full in 3rd then boost cut)
Will be ordering a maf tomorrow from Seat, my experience with the recon Bosch units from factors etc was pretty poor.
