MK4 Brake Upgrades
STOCKY
Audi TT 225
Oct 6, 2004
1,005
N.Ireland
Please post any useful info in this thread which will hopefully become sticky.
Include opinions if you have one and links to previous threads and prices and part numbers
DO NOT POST CRAP IN THIS ONE IE DONT GO OFF TOPIC
Both Petrol and Diesel Please
This thread will be made Sticky if there is good feedback on it that will help people in the future
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
some people have also said on this to make sure u get TT calipers as the leon/S3 versions seem to be slightly different sometimes.
if u have a 130diesel car or indeed 150petrol, they bolt straight on , as do seat sport calipers . these are 4 piston items used on the cupra and utilise a 312mm disc as well , the caliper is also larger than a brembo 4 piston caliper, however u will need aftermarket alloys to clear these , or ibiza cupra alloys,
these calipers are 270 quid from ur local dealer , u will also need new brake lines , plus discs n pads
Reactions: DrGile
andy_gdon
494
i fitted the 312mm TT Brake conversion to my 130pd sport but also added Pagid pads.
After a few weeks-allowing plenty of time to bed in i can confirm that these are the mod to make before any power up grades!
Only problem to be aware of is the copper washer attached to the brake line that joins the caliper. This is a slightly odd shape and sometimes does seat right, causing leaks...and mad beeps warning of low brake fluid!!
A few pics for you!!
Before....
Just after being fitted...
Better pic...
http://www.reallymeansounds.com/reports/phpslideshow.php?directory=205/big&currentPic=15
greggy
Does anyone know what kind of tourque the 18mm bolts for fitting the caliper carrier require - I have heard some people have removed the thread on there hub - something i dont want to have to afford to fix!
Thanks for your help.
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
id say use a torque wrench to remove them , gradually increasing the setting till they loosen , then just reverse the wrench ,
my 2 pence
BlackFR
1,724
Not too far away
Undoing torque isn't always the same as doing up torque though. You may have to wind on more force to crack the bolt away where corrosion has set in, doing it back up to this torque is likely to exceed the specified value.
greggy
Thanks - Hoses Too?
Thanks for the ideas - I was thinking i might stop being cheap and take it in to the experts
Any idea if JBS are any good at this kind of thing - they look like the nearest set of peopl id trust to work on the car.
Also - I have been looking at hoses - the set of callipers golfturo has sent me is without hoses - Sent of a request to goodrige and they are happy to supply me with just audi TT225 front hoses - (See below) Anyone using these at the moment?
Yes, no problems
Just order a set on line and in the "comments" section on the order
form
highlight the fact that you only want a front pair and not the whole
kit
I'll adjust the price and details manually at my end
Good luck
Ian Goldie
C.A.M. Auto Developments Ltd
Tel: 08700 780517
+44 1727 827717
Mob: 07850 397624
Fax: +44 (0)1727 827455
Web: www.camauto.com
www.brakehoseshop.com
www.exhaustwrapshop.com
Madz
someone know any brembo GT kit that will fit on it ? can i take a kit from another VAG car ?
Ibi Fr
yes in holland we have one with a Junior GT Kit on his Ibiza.
I will look for some pictures!
Ibi Fr
here it is
[quote author=FRed link=topic=26006.msg452921#msg452921 date=1148091584]
Gisteren eindelijk een remmen upgrade gedaan.
Wat is het geworden; Brembo 4 zuiger remklauwen met 323mmx28mm schijven en rvs leidingen.Het is een complete kit die eigenlijk voor de Leon I is, maar perfect en zonder aanpassingen op een Ibiza 6L past.Dus dezelfde maat schijven en klauwen als van een Leon Cupra R. :lol:
Natuurlijk past het alleen met 17” wielen en spacers.
Voor het zicht heb ik achter ook maar gelijk de klauwen rood gespoten en geboorde schijven met Ferodo blokken gemonteerd.
Voor de liefhebbers; ik heb het gekocht bij Biesheuvel. Eind vorig jaar was er een aanbieding.http://www.seat-online.nl/index.php/topic,21077.0.html
Misschien kan Antoine nu ook nog een nette prijs maken.
Montage heb ik zelf gedaan.
[/quote]
Madz
Nice
Nice :D but my dutch is not the best ;) so i can just order a GT kit to a Leon and it will fit perfect ?
Ibi Fr
Haha i will translate it a bit for you all.
He had to put 20 mm spacers at each wheel to fit the brakes. BUT he is driving with the OZ rims with 7j and ET 37 i thought.
So he is driving right nouw with ET17, if you count the spacers within.
Good Luck!! If anyone has more questions.. ASK! I will translate it and will ask your question to him.
skorv
Ibi Fr.... what is the serial number of that kit from brembo? is it 33.0019.04/06?
Thankz
Madz
yes thats the serial number...
33.0019.04/10 is for the Slotted disc
