allan@ur
Looking for a spare wheel for the leon. It has 18inch wheels on it so not sure which size spare I need?
And I've got 18" wheels with an 18" spare but no SEAT Sound...
Just been experimenting with the online configurator to see what it allows with certain trim/wheel combos:
15" steel wheels (base spec only) can only have the 16" spare
16" or 17" on any model can have either size spare
18" or 19" can only have the 18" spare
Checked on both SC and ST. It also seems that you must have the 18" spare in order to have SEAT Sound.
Both sizes have 125/70 profile tyres, so your tyre is 2 inches smaller in diameter than it should be if you're using the 16" instead of 18" spare. Doesn't sound ideal to me... although I suppose the 70mm tyre on an 18" spare wheel would make the overall diameter 60mm larger than the Performance wheels anyway...
a 16 inch space saver seems a little strange, ive got the 18s on mine and the space save I have is 18 inch also
Not at all. The rolling circumference of the tyre is the same irrespective of whether you have 16,17 or 18 inch wheels. As long as the wheel does not foul on the brake caliper it will be OK.
