urgent help needed
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
a picture is worth a thousand words
i was driving home and felt a jolt through the whole car that felt like i was crashed into, at first i thought it was the exhaust had fallen off, got home to find the engine looking a bit lower than normal, and it moves about when rocked, looked under the car to check the exhaust and saw the bolt (or what i think would be a bolt) is missing from (what i think is) the dog bone mount bracket to the engine.
if anyone has any ideas how to fix this or if it is a bolt what size i need to get cos i dont feel safe driving it and i need to get to work in the morning.
please hhhhhhheeeeeeeellllllllllppppppp :cry:
Steely
semiskimmed cupra R
Dec 30, 2008
1,425
Doncaster
has the bolt sheered? or just worked loose? you re missing 2 bolts one in the dog bone & one in the bracket
Reactions: Dozer360
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
So hard to tell if the threads are knackered.
The engine will move back and forward dead easy now, putting more strain on the remaining mounts.
csd_19
2,279
28
Angus / Edinburgh
As well as putting a lot of strain on your downpipe/exhaust.
I'd say don't drive it until you get the bolts replaced, as Lee says the engine will move around a hell of a lot - if you've ever seen a stock 1.8T on the dyno the engine moves a fair bit anyway. With no dogbone mount attached it rocks really easily, even by hand.
csd_19
2,279
28
Angus / Edinburgh
Can't really tell about the rear bolt hole but the front one looks okay from the last picture there :)
Have you had a new sump recently? Looks very shiny lol.
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
do you think it will survive another 4 miles to the garage if i can get them to look at it, im sure its gunna be much easier to fix on a 4 post lift than on the edge of a pavement.
csd_19
2,279
28
Angus / Edinburgh
You'll have to rock the engine back to its normal position before being able to see the threads through the dogbone mount, either that or unbolt it completely from the subframe.
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
Personally, get it towed, don't get it there under it's own power.
i have no way of getting it towed, its done about 6 miles like it just to get it home, there are 3 garages near my work so ill have to call up early before i leave and see if they can fit it in
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Bolts are M10. Be very careful if you put a substitute in. Gentle driving, smooth gearchanges, no rapid torque changes. The bolts should be renewed every time they are disturbed. You need new bolts from a VAG dealer.
Has any work been done to the car recently that would need the engine mounts to be disturbed? Those bolts have not been tightened properly.
Dan1720v
1,928
Street, Somerset
Don't drive it. Get the aa to tow it or something. Carry on driving and you'll snap the studs in the turbo, and you'll have created about 6 hours work, for removal and refitting of the turbo and drilling out the sheared studs and refitting new ones.
You don't HAVE to renew the bolts, it's advised, but I've had my box off 3 times and never renewed them with no issues atall.
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
I couldn't get on to vagcat ( I saw ur link in another post).
Do the aftermarket ones all come with bolts? I know awesome do a kit but it doesn't mention any bolts.
