Tools/Parts needed :
LED 264 bulb 44mm (I used white but it's up to you)
Old credit card sized card
Tissue/Toilet Paper
Car used :
10 Plate Ibiza 1.4 SC Sport
Time needed :
3-4 Minutes max
Difficulty :
1/5 - The cat could have done this!
I'll be using these bulbs
£4.20 From Ebay including delivery
Other bulbs can be used of course!
Let's start by having a look at the original bulb..............nice!
Take your old credit card (old gym card for me!) and push it in the gap on the right hand side between the bulb cover and car.
If done correctly the holder should pop out
You can now pull it out from the bodywork a little
Next you need to unclip the power source from the bulb holder, you do this by pushing the black holding clip inwards and pull on the plug
This Will leave you with this
**BEFORE YOU START THE NEXT BIT BE CAREFUL AS THE BULB MIGHT BE HOT DUE TO BEING ON - IF YOU ARE WORRIED THEN LEAVE IT TO SIT AND COOL DOWN FOR 5 MINUTES**
Tissue/Toilet Paper
Car used :
Time needed :
3-4 Minutes max
Difficulty :
