10 vag codes!!!! Problem continues
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
Ok fitted my exhaust day before yesterday, and fitted my second lambda sensor again, and cleared all codes.
All was fine for 2 days.
Just now driving back from work on highway TCS light comes on and boost is only up to
.04 bar (usually peak to .06)
got home, switched off car, then switched back on and engine management light comes on with TCS light
read the codes and I have 10!!!!
I have MOT in 45 minutes...F***K always same crap
these are the codes
16486 P0102 Mass or Volume Air Flow Circ Low Input
16518 P0134 O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected
17833 P1425 Tank Vent.Valve Short to Ground
17955 P1547 Boost Pressure Contr.Valve Short to Ground
17843 P1435 Sec.Air Inj.Sys.Pump Relay Circ. Short to ground
17829 P1421 Sec.Air Inj.Valve Circ Short to Ground
17697 P1289 Turbocharger bypass valve short to ground
17525 P1117 O2 Sensor Heater Circ.,Bank1-Sensor2 Short to Ground
17522 P1114 Bank1-Sensor2 Internal Resistant too High
17523 P1115 O2 Sensor Heater Circ.,Bank1-Sensor1 Short to Ground
please help!
seems like something to do with short circuit or battery connections but they all look fine...
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
its under drives steering wheel in ares but dont know if pasanger side as your is left hand drive, just pull cover off
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
you mean one of these?
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
yeah ok....found it now
there is one brown one which is burnt through/
gonna go buy a new one nw and I'll see if that fixes it...
then to MOT...better be that one! lol
although can't really laugh about this...any other day would have been ok...
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
hey mate chris, gotta say a huge huge shout of thanks goes out to you. I am slightly color blind so thought it was brown but its actually red!
Got a new one and all is well again! 10 codes deleted and boost is back to normal!
Car is at MOT station (vw Adui dealer) now, but when I get it back I will take a picture and circle the one you need to swap when this happens to anyone else in the future.
again chris thanks!
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
no problem mate had it afew mins on mine why i knew what it was straight away. would of said waht number it was if could look at car but in work. least you got it sorted now! :)
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
yeah cheers for that
however, I failed MOT
I have a decat and it was a no go...now I'm gutted. I need to put my old DP back on, however then I have to go from 2" DP to 2.5" catback. Hwever they do not seel those clamps in that size (reducing) anywhere here.
DO you think that if I used a forge silicone hose in that size it would be allowed?
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
Im sure if you used one of the forge silicone hoses it'l get it through the MOT but would take it straight back off after mate. Gungum will just get blown clean out so no point using that reuvers.
Was it only the decat it failed on?
