VAG COM Help..... UPDATED WITH LOGS
Adam R
Diesel ISN'T a Dirty word
Mar 5, 2007
2,851
lee in the solent
hello all.
i have a 1.4 mk3 ibiza cool/s and have an engine light up. first things first is i have got hold of VAG com from a mate inc a cable so should be able to find the fault.. but me never using this program before, i have no idea what to do.
also is it possible to program in:
1 touch widows
welcome lights (headlights turn on when you unlock the car)
also i have a problem with my AC and will this also show up a fault or not ?
sorry about my dumb questions, i did search but it came up with nothing.
any help if great thanks
Adam
rhysox
Ibiza Cupra 1.8T
Jun 18, 2007
438
Cardiff
1 touch windows are based on the switch
welcome lights- no idea, but very much doubt it.
you can check the AC module within vag-com for faults
Adam R
Mar 5, 2007
2,851
lee in the solent
ahh ok will try and get them then!
also guys. i am now sitting in the car with the lapton on my legs... and i cant ruddy connect to the car. keeps saying that the port statusis ok but the interface is not found..... grrrrrr any one shed any light???
Adam R
Mar 5, 2007
2,851
lee in the solent
updated with some codes....
Code:
VAG-COM Version: Release 409.1-US
Control Module Part Number: 6K0 906 032 J
  Component and/or Version: ME7.5.10            S157
           Software Coding: 00001
            Work Shop Code: WSC 06402
8 Faults Found:
17733 - Knock-Control: Cylinder 1: Regulation Limit Exceeded
        P1325 - 35-10 - - - Intermittent
17735 - Shareware Version. To Decode all DTCs
        P1327 - 35-10 - Please Register/Activate - Intermittent
17736 - Shareware Version. To Decode all DTCs
        P1328 - 35-10 - Please Register/Activate - Intermittent
17734 - Knock-Control: Cylinder 2: Regulation Limit Exceeded
        P1326 - 35-10 - - - Intermittent
17794 - Shareware Version. To Decode all DTCs
        P1386 - 35-10 - Please Register/Activate - Intermittent
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
        P0420 - 35-10 - - - Intermittent
18010 - Shareware Version. To Decode all DTCs
        P1602 - 35-10 - Please Register/Activate - Intermittent
this is also for my sound system, as i have been having faults recentyl
Code:
Control Module Part Number: 6K0 035 156 A
  Component and/or Version:  Radio GRO         1V32
           Software Coding: 00401
5 Faults Found:
00852 - Loudspeaker(s): Front
        36-00 - Open Circuit
00853 - Shareware Version. To Decode all DTCs
        36-00 - Please Register/Activate
00856 - Shareware Version. To Decode all DTCs
00779 - Outside Air Temp Sensor (G17)
        30-10 - Open or Short to B+ - Intermittent
00658 - Shareware Version. To Decode all DTCs
        45-10 - Please Register/Activate - Intermittent
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
Well you can ignore the "Shareware" based codes as that is down to the cable and software.
The16804 code relating to lambda/oxygen sensor, I think this could be causing the problem with the knock controller too. Its probably causing the A/F mixture to run lean giving you lots of excess knock (pre-detination). Drive carefully mate.... Knock is really bad for the engine.
I would think about changing the o2 sensor/s.... If you can't log the outputs to see which one is duff, then perhaps change them both... pre and post CAT.
Hope this helps.... That would be my first thought anyway!!
The speaker and temp sensor ones are due to wiring issues I think... Perhaps a new temp sensor is on the cards if you can't find any probs
Adam R
Mar 5, 2007
2,851
lee in the solent
so what do i need to replace then (apart from the pre cat lambda sensor). i cleared the codes and my engine light it back on so something isnt right with the engine, would changing the cam belt help at all as its nearing its the milage where it needs to be changed.
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
Change the pre cat Lambda sensor first. Clear the codes and see if they come back....
Changing the Cam belt won't help. However, if its nearly up for renewal, you need to do it. Its nothing to do with these codes though.
Adam R
Mar 5, 2007
2,851
lee in the solent
i know this is a bit stingey, but would it be worth looking around for a crashed 1.4 mk3 (same as mine) and taking the sensor off that? i dont really have £100 to spend on a little sensor!
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
It wouldn't really be worth it bit as they are screwed into the exhaust, they tend to get really corroded and are a bitch to get out.
Also, if you had a new one, at least you know it either has solved the problem or not for defintate.......
