After driving the Cupra around this last month I have decide to put in a custom exhaust system next month. With that in mind I wonder what the car would sound with the stock OEM resonator removed with a straight pipe put in its place.
Went to a local exhaust shop that did it in 15 minutes for 20 euro. They used a 65mm pipe that was tapered so the two cut ends where the resonator had been fitted perfectly.
Sound at idle was slightly louder but when driving you could now tell the car was announcing itself. For those that like a louder exhaust it was a nice note with the stock muffler still doing an excellent job. Droning in the car is to be expected but in the front not too noticeable though back seat passengers might have a bigger problem.
Power band was still the same, as expected....
Overall for 20 euro it made a bigger impact then the Forge spacer when it comes to performance noise... and is cheaper as well.
On a side note the OEM exhaust is something to modify. I would look at the down pipe as well as higher flowing cats..... I am not sure but the stock exhaust is around 63mm(if anyone knows please let me know) so a nice 76-77mm exhaust diameter would be perfect....
