front suspension mounts...
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
mot failure on the Cupra.. :(
need to get these done (obviously) what kinda price am I looking at ? anyone have any ideas? suppose I can order the parts up myself, but is this the kind of job you can do on your todd without buying spring holders etc.. timescale on job? ... would it just be easier to get a local mechanic to do?
any thoughts/ideas (from those that have done this stuff) appreciated
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
undo top mount nuts (22mm nut/6mm allen key I think)
jack both sides of the car up so teh front wheels are in the air.
Gravity will pull the shocks down & you can just reach into the turret & remove the rubber top mounts (and replace)
then lift each strut up and reattach the nuts (I tend to lift the wishbone/hub with a jack to control it easily if working alone)
quick and easy if you can not remove the strut
if you do remove the strut it's only 2 bolts per side, and not worth loosing sleep over as it'll only add 10 mins to the job - but will need aligning afterwards
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
so , am I right in assuming its this thing (or both of them?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
yeah - that's the kitty - get a pair of them together and you're away
GSF/ECP are fine - and sell the right parts
Feb 20, 2005
3,476
Telford ay it...
Did mine the other nite mate, jenks 9pm motors. Took an hour max. Just as m0rk described ;) Think i payed £22 for both from GSF bearings included. They have them in stock aswell.
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
dont they hold the spring then guys? cus i would of thought if they did you need to remove the strut, put them in a spring clamp, compress one spring and remove mount
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
that the one in Oldbury/Smethwick??
will get my ass down there in the morning before i go hit my first job , I think
Mckellar
no they come off without needing to take the strut off, iirco they arent actually held in place with bolts, but with forces from the strut being pushed up and it holding onto the bolt from the top mount in the engine bay
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Im talking about WORK ;) .. i have a coachlight outside my house that has a motion detector on it, Ill just have to remember to turn the 'machine gun' off ;)
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
thats the thing I 'supposedly' do all day. well for about five hours or so , anyway.. spose I better suss out if Ive got any Allan keys and a 22mm socket .. I got a wrench so that aint a problem
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
sounds easy enough :) should get it done over next couple of days .. get it back up to the MOT station and then get things moving again ready for the summer :)
ibiza_95
1.8T MK2 Conversion
if youve never taken the front struts off... or undone the top bolt prepare for perhaps the biggest ball ache youve ever had... the allen key hole is just ever so slightly bigger than a 7mm allen key and ive managed to round mine off... then had to cut a slot in the damper to get a spanner in there to keep the strut from turning :(
