Exactly, I also assumed the little triangle indicator is a LED. The covers on the headlight have stickers with warranty void, thats why I concluded that the indicator was not serviceable (read: not a normal bulb)On your facelift (generally 2017 onwards) LED headlights the DRLs and indicator are combined.
On the PFL (up to 2016 generally) LED headlights, the indicator is a separate LED at the top of the light unit, as pictured by @tracktoy.
There is also the halogen headlight option which has a normal bulb for the indicator.
100% correct good sirExactly, I also assumed the little triangle indicator is a LED. The covers on the headlight have stickers with warranty void, thats why I concluded that the indicator was not serviceable (read: not a normal bulb)
And the rear indicator is only a bulb on the PFL... Which is why the FL tail lights look wayyyy sexierYes my bad its the rear LED lights that have bulbs
Without checking, tail lights come in 2 flavours, full normal bulb or LED/bulb mix (FL only have a bulb for the reverse light) and you have LED/bulb mix and what looks like an aftermarket LED replacement bulb in your reverse light.I didn't even look at the rear indicators, so these are the standard ones on the face lift?
Yeah the previous owner did a few little mods, led bulbs, some obd stuff like dials illuminated all the time, needle sweep etcWithout checking, tail lights come in 2 flavours, full normal bulb or LED/bulb mix (FL only have a bulb for the reverse light) and you have LED/bulb mix and what looks like an aftermarket LED replacement bulb in your reverse light.
Ah, thanks - had always presumed the separate LED was a halogen.On your facelift (generally 2017 onwards) LED headlights the DRLs and indicator are combined.
Nice stuff, I'm still getting used to what this car has and does.@WozzaB see the difference with my units
I replaced the fog light bulb with the red "hyperflash" on the left, and the reverse light with the "hyperflash" LED on the right. The middle bulb is a single CREE LED, which is already a major improvement over standard halogen
Standard for LED light package. Without the LED package (halogen not LED headlights) the rear lights have standard bulbs fittedI didn't even look at the rear indicators, so these are the standard ones on the face lift?
