The dreaded turbo actuator rattle 1.5TSI
Mr Pig
2,796
1,022
When refitting the rod/clip I would suggest using some high temperature paste/anti seize - as they can seize solid, common on the 1.4's to seize and stop the waste gate working.
Maybe they made the later version looser - so less chance of it seizing - at the expense of more chance of it rattling :oops:
You don't need to replace the clip. The high temperature grease is enough to stop the rattle and stop it from seizing. My son has a 2017 Ibiza which suffered a seized rod, I'm guessing four years ago. I worked some grease into the ends of the linkage and it's been fine ever since.
My car is a 1.4 tsi. Not had a seizure but the linkage did rattle. The grease stopped the rattle and it hasn't returned. Again, that was four or five years ago. I intend to add more grease once a year but I've forgotten about it and never done it.
You don't need to remove the clip or even be looking at it. Just put a rubber glove in and work some grease into the linkage with your fingers. Too much won't do any harm. You want the correct Loctight grease and it's expensive but totally worth it as the problem is solved.
Reactions: SuperV8
decker53
29
19
Hi is there a way you can show how you have installed this? Also how long have you had the clips in? Iv heard in a lot of forums that they tend to fall off very easily. The sound is driving me crazy. Can hear it whilst travelling at low rpm
I’ll try and post a pic, had them installed for a week now and they’ve not moved at all, maybe others have used a different clip hence why they’ve fell off. The ones i got still allow free movement of the rod but just take up the slack enough to stop the rattle. I was also wondering about them falling off but after a week they’re still in place
Reactions: Walone
decker53
29
19
Sorry for the delay, forgot all about the photos, but here you go
decker53
29
19
Update, because of the negative review I left about Crewe Seat, they have been in touch and said this should have been booked back in and repaired under warranty, and even if it is declined under warranty they will fix it free of charge as a good will gesture. I sent them pictures of the " turbo wastegate rod repair kit " and said if there's not a fix, why is this advertised as such
Jan 1, 2025
Canterbury
I have the same rattle, has anyone found a TSB for this?
I bought mine at the beginning of the year as approved used, its been in once for the rattle and they have tried to hide it instead of fixing it.
When I go back I want a bit of information to give to them.
decker53
29
19
Hi Andy, mine goes in on Tuesday for the “ fix “ so I can’t really help until then, but I’ll post here my findings on what they’ve done
Reactions: Andys101
