Fail MAP
Feb 13, 2025
Hello everyone!!
I just bought a León Cupra mk2 with 387 hp, BWJ engine, and I have a problem, I bought it knowing that the flow meter was bad... they are not worth much so I didn't give it importance, the issue is that I have already installed 3 flow meters and none of them work... I am attaching photos of the diagnosis to see if someone can give me a hand
Could it be that the map is poorly made? Or do I need a flow meter with a higher flow rate?
Thank you very much in advance
mty12345
4,021
629
bristol
How do I check? It doesn't understand electricity well, the MAP connector only has 3 wires
It's the MAF sensor not the MAP sensor, they are 2 different things.
Unplug the plug, use a multimeter to check you have voltage on one of the pins. When you find that pin, try moving the wiring around and checking if the voltage disappears in a certain position. Use thin probes and don't push them into the connector, or you may spread the pins open too far, just rest the probes against them. If you're unsure then maybe just best to take it to a garage.
This video may help you.
Feb 13, 2025
Sorry friend .. MAF sensor I got the wrong letter haha thanks a lot, I will try to test it in the next few days, if not I will go to a workshop as you told me
Feb 13, 2025
Have you checked the wiring to make sure it's not a broken wire or damaged connector?
Friend, I did the tests, with the ignition on and then with the car started, these are the data...There is no big difference in data between the ignition and the car started…
Pin 1 : 5.02
Pin2 : 00.03
Pin 3 : 00.62
mty12345
4,021
629
bristol
The data looks good.
The fault code was set because at some point the 5 volts on pin 1 was not there. If you look at the freeze frame data on your fault code, you can see that the code was set when the engine was hot (89C) When things get hot they expand and it's possible that the fault only shows up when the plug or wiring is hot.
New connectors are not expensive, if it was my car I would try replacing the connector and the wiring with a new one. Try to buy one that is high quality. They are 'Mass air flow harness repair kits' or sometimes called 'MAF pigtails' in english.
You will have to find the right one for your car, but something similar to this example below:
If you can use a soldering iron then you can do it youself fairly easily. If not then a garage/workshop should be able to fit it in less than 1 hour for you.
