Model Year 23/24 Large void behind rear bumper
DaveSmith
15
8
I've noticed there is a large void behind the inside of rear bumper. Ot looks odd and I'd expect it to be covered by a tray or something similar. Is this normal? Can others please check their cars to see it they are others like it.
SRGTD
2,606
1,455
Pretty certain it’s to accommodate a tow bar. VW’s Golf (certainly the mk7.5 Golf) has a similar recess and it doesn’t have a cover.
So I suspect it’s how it’s meant to be on the Formentor too, and cars probably leave the factory with that open recess.
Spivvy
284
136
UK
Perfectly normal it's for the towbar assembly
I hated it so I got a maxton splitter to fill the gap
Sent from my Pixel 8 Pro using Tapatalk
DaveSmith
15
8
Still think it should have had a removable panel fitted as standard, as most users don't tow nowadays.
Agreed. Not only does it look naff and wrong, it will allow **** to spray up into it and look messy and promote corrosion. Very difficult to clean out too. I will look to find an aftermarket cover for it. If I knew what to search for.
